D dynamc New Member Jan 10, 2008 #1 How do you access SSH? I tried using the login in the VPS CP using root as my user and the password I used to login to the VPS CP but all I get is a blank screen...
Dan Moderator Jan 11, 2008 #3 Hello Dynamc, The built in clients do not support changing the SSH ports so you will need to use a SSH client Putty. And as Mylinear said change the port to 2200. Hope that helps
D dynamc New Member Jan 11, 2008 #4 Alright, so for the Host Name field I put in my server IP and set port to 2200 and open?
P ppc Moderator Jan 11, 2008 #5 dynamc said: Alright, so for the Host Name field I put in my server IP and set port to 2200 and open? Click to expand... That is correct.
