How to get rid of questioner slid out in WHM/cPanel
As requested see attached
Hello,
It's usually because the cPanel Analytics is enable in WHM. Please see screenshot on where to find it and where to disable this feature. Even after you disable this feature, the corner smiles will stay for a while. It will go away after a few days or a reboot.
I had not see this corner smile until I enable the cPanel Analytics.
Jean
Thanks for the tip but when I checked the cPanel Analytics was off so no luck yet.
I'd clear your browser cache, removing cookies/sessions, etc and then re-login. cPanel caches everything so it would make sense that it still persists afterwards.
I think Jean is right, however that this icon belongs to cPanel Analytics.
Top
