L L4D-Marc New Member Apr 28, 2009 #2 I doubt it. It's usually set for the whole server and loads of scripts won't work with it turned on. Sometimes you can add a php.ini file in your webroot http://www.washington.edu/computing/web/publishing/php-ini.html I would think it's turned off here though as it's a bit of a security risk.
